Lost a Trun signal today!!
Old 10-20-2011, 06:56 PM
T/A2000's Avatar
Default Lost a Trun signal today!!
On my way to work today and my turn signal stopped flashing.. get home tonight and this is what i find!!!
Blown bulb, and a burned connector
What should i do to keep this from happening again?
Old 10-21-2011, 07:41 AM
Save the manuals!
wssix99's Avatar
Looks just like every other one in existence. Try searching for details.
Old 10-21-2011, 02:54 PM
T/A2000's Avatar
UH OK thanks! The problem i have with your statement is the other one don't look like this.. But thanks for the help anyway
Old 10-21-2011, 08:24 PM
Save the manuals!
wssix99's Avatar
Odd... How many miles do you have?
Old 10-22-2011, 10:49 AM
T/A2000's Avatar
Old 10-22-2011, 12:21 PM
FiredUpZ28's Avatar
I'd solder/crimp a new socket in (like 15 bucks at the parts store) , use the CORRECT P/N bulb, and use some dielectric grease when installing the bulb. Also make sure there isn't any condensation in the housing - that would lead one to think there is a crack somewhere letting moisture in. Take those steps and you shouldn't have any issues. Using the wrong bulb can cause it to fry because the resistance isn't right. A lotta people just shove in any dual filiment amber bulb that fits, and thats not the correct procedure.
Old 10-22-2011, 01:59 PM
Save the manuals!
wssix99's Avatar
90,000
Wow. Mine were singed like that after 50K. Have you tried a new bulb? If so, you can also replace the socket without crimping.
Old 10-23-2011, 10:15 AM
T/A2000's Avatar
yeah i did get new bulbs (correct ones) and they work, it just looks like it melted in a few spots which worries me a little bit.. I know that I am going to need housings at some point i see some hair line cracks starting to form on the corners, no water in them yet though so i have a little time to worry about that
Old 10-23-2011, 05:42 PM
donati98ta's Avatar
running light housing cracked ?
Old 10-27-2011, 03:13 AM
TruBloodTransAm's Avatar
I bought new DRL housings off eBay a while back, they're pretty good quality actually. If you ever need new ones, try to get some manufactured by DEPO auto parts.
