Replacing Steering Rack...
Old 10-24-2011, 07:19 PM
Nick_Rapitis's Avatar
Default Replacing Steering Rack...
My steering rack is leaking and I'm not sure where exactly but I read that I would most likely need to replace the whole thing and not just a gasket or O-ring. I dont have the time or willingness to do it myself right now...
Does anyone have an idea of how much this sort of thing might cost? The part is about $300 but I'm curious about what a mechanic might charge for labor...
Any help would be great! Thanks!
Old 10-24-2011, 07:22 PM
VinR1's Avatar
Do it yourself - shouldnt take more than two hours in your driveway on jackstands
Two hard lines, a nut at the end of each tie rod, and two bolts/nuts is all that holds it on. Oh, and the steering shaft.
Old 10-24-2011, 07:27 PM
Yeah but that's a problem right now. My driveway is dirt and gravel at the moment since I'm getting a new one poured soon. If it would only take me a couple hours, it couldnt cost too much for my mechanic to do it...
Old 10-24-2011, 08:00 PM
LS6427's Avatar
Its that bullshit labor book that they go by though.........almost every mechanic on earth can beat all those times. But they charge you anyway.
Old 10-26-2011, 03:20 AM
sjsingle1's Avatar
are you gunna raise the engine or cut the bolt............to get the drivers side bolt out?
Old 10-26-2011, 03:38 AM
02sleeperz28's Avatar
FWIW, I will be selling my power steering assembly very soon. Everything still works perfectly and it is being replaced for performance reasons only. Parts from a 02 Trans am auto.
Old 10-30-2011, 07:45 PM
FiredUpZ28's Avatar
I'd say its like 2 hours of labor plus setting toe. Its a very easy procedure but you gotta bleed it right and check the alignment. Should just be a toe set. At our shop we use Alldata as a guide and its not all that generous. Sometimes we add time if its an older car because things like electrical and suspension can be a major PITA, especially considering the way people take car of and maintain their cars.
Old 10-30-2011, 08:04 PM
3Camaros's Avatar
I got a rebuilt rack from Rack Doctor, just checked their site price $120 http://shop.rackdoctor.net/2000-2002...995-3570-C.htm
You will probably want to do tie rod ends at the same time, then you need to decide Chinese or Moog.
Two hours is not realistic, I probably spent that much time cussing at the drivers side bolt before I decided to lift the engine.
Quick Reply: Replacing Steering Rack...
