Rear defrost--help please
Tried searching but I couldnt find what I was looking for. My rear defrost turns on but for only a short time (1-2min) then off. Then I cant turn it on again for bout 5 minutes. Then it will stay on for bout another minute then off. What do I need to look at for fixing this problem?
wrencher
Well if it goes out early & wont come back on for a few minutes I'd check the circuit breaker. It powers the circuit including the light in the switch when on.
other than that the timer relay might be an issue also.
Most likely it's the breaker (the ones with the shiny silver top) in the fuse panel that's in the dash. It wears out and trips early. Don't remember exactly which one it is but it's in your owners manual. Most people (including myself) replace it with a ? Amp fuse. You just have to make sure it cuts off in 10-15 mins or it could burn something up. I have had it like this for a year w/o any problem.
If you want to replace the breaker, its in the panel in the dash. Take it into the parts store and match it up. It will burn up again but some people just like having the piece of mind. Most of the time the timer will kick in and shut it off anyway.
Try the fuse. I don't remember what the correct amps are but it's whatever the breaker is rated too i believe. I'll take a look here in a min and post it up.
I bought my 96 with 74k on it and it has done it ever since, I bought my 01 with 34k on it and it has done it ever since as well. I'm not sure if it is a known issue or if it is functioning as designed. Either way neither of mine are even worth turning on. I'd like to know how to fix it as well.
Save the manuals!
This IS just your breaker getting old. (There are other posts on this.) Just put a new one in and you'll be set for another 10 years.
DON"T put a fuse in its place. The engineers put a breaker there for a reason... Fuses and Breakers trip at different time intervals.
OP put a replacement breaker in it. If that breaker wears out as fast as mine did, put a fuse in it. The timer will cut it off before anything bad happens.
LS1Tech Administrator
Received 1,492 Likes
After owning 4 of these cars, ranging from brand new to 100k+ miles, I've never had this problem.
Whatever it is, it's not normal and isn't how they were when new. So something needs to be replaced somewhere to restore proper operation.
Save the manuals!
My camaro has this problem when the car is cold. If I warm the car up and then use the defrost it works fine.
My theory is that it's the switch. It won't fully click into position after its been on a while and my theory is the switch can sense resistance in the defrost
I have switched the breaker. same result. put a 30 amp fuse in with same result. I guess its just not gonna work. it car sit in the garage and think about it. haha
