02 Sensor Locations
02 Sensor Locations
So my car (2000 TA) threw a code P0161 this morning on the way to work. The code returns as:
P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2
I have searched and searched and cannot find anything that shows which sensor is which. My question is which side is bank 2 and which sensor is sensor 2? Would that be the sensor on the passenger side after the cat?
Also, if anyone has a link or diagram or something showing all 4 and what they're called, please share for future reference.
Thanks!
Thanks!
LS1Tech Administrator
Received 1,524 Likes
That is the passenger side sensor, post cat.
B1S1 = Driver's front sensor
B1S2 = Driver's rear sensor
B2S1 = Passenger's front sensor
B2S2 = Passenger's rear sensor
Thanks!
Thanks!
Did you buy one of the portable computers? or a link?
Thanks!
http://www.harborfreight.com/can-obd...enu-98568.html
It was ~$60. They have others that are a bit more and do more stuff, but this is enough to get the code you need. Just plug it in to the ALDL port under the dash, turn the ignition on and read the code. You can clear them too.
I went to Harbor Freight and bought this:
I'm assuming this would work on a 99 WS6 as well?
Thanks! again
