Car stays @ 3k rpm when fired up.
Old 11-29-2011, 06:17 PM
wichoms4's Avatar
Default Car stays @ 3k rpm when fired up.
My has been sitting for about two months without getting fired up. Went to fire it up n the car stayed accelerated at 3k. Don't knowwhat it can be. Before that I had fired it up n it never did that. It's a 98 SS camaro.
wichoms4's Avatar
No the cruise contral in not on or stuck.
Old 11-29-2011, 06:24 PM
LS6427's Avatar
Either your TB is sticking open a little bit because its dirty around the inside of the TB.....or the IAC valve is acting up.
Old 11-29-2011, 06:55 PM
Floorman279's Avatar
grrrr everytime i see a thread like this everyone always assumes the blade is stuck or IAC......not that they are wrongbut if its been sitting, its possible the batterys not the best or that the computer for some reason doesnt know where to idle at......i was having the same issue except mine was at 2500 when my battery was bad.......i would let it idle at 2500, rev it up a little, and it would still just return to 2500.....the computer doesnt know where to idle sometimes and it needs to reteach itself if for example the battery is going bad.......drive it for 5 to 10 minutes then stop.......if it idles fine, then check your battery.....i replaced my old ac delco and the problem went away
Old 11-29-2011, 06:59 PM
hevymetalg's Avatar
Did you try to let it warm up? Snap the throttle? Check vac lines?
Old 11-29-2011, 09:11 PM
14k
14k's Avatar
mine did the same but 2k my blade was open.
Old 12-04-2011, 03:26 PM
BandDirector Blk98ZM6's Avatar
I agree with the battery assessment. I bought my '98 new and I've been through several batteries over the years and sometime when I'm getting ready to lose one, or if I need to jump it off because it's been sitting, then it has no idea where to idle. Usually letting the battery charge for a while and then restarting it a couple of times cures the problem....
Old 12-05-2011, 04:39 PM
johnny89345's Avatar
mine would do this when i had an intake manifold leak.my manifold came loose and caused to idle to stick really high randomly.
Old 12-05-2011, 06:48 PM
weak batteries can do some crazy stuff to a car
Old 12-05-2011, 06:49 PM
when mybattery wasdead, after driving afew milesmy idle was fine....again thatdoesnt rule out battery, but just sharing my experience
Old 12-09-2011, 07:15 AM
BlackLS1Bird's Avatar
X2. All the sensors need th correct amount of voltage. Even a small drop and they start to act up.
Old 04-28-2012, 02:05 AM
wichoms4's Avatar
Thanks everyone for the info but I need to replace my intake seals. The old ones were worn out n had a leak.
