HELP WIFE's 05 GTO wont start
It left her stranded friday night after work. It wont even click when you turn the key. I hooked up the Diablo predator tuner to it and pulled out 2 codes
P0335
Crankshaft Position (CKP) Sensor Circuit
P0340
Intake Cam Sensor Performance
I replaced the crank sensor and inspected the harness, had the starter tested and battery is good. Still will not even click. completley dead. I have checked for loose grounds and have found none. Im lost and i really dont want to take it to the dealer if possible.
P0335
P0340
no i didnt replace the cam sensor as you have to pull the crank pulley to get to it. and i also did not check the bcm. The car has been running fine this just happened out of nowhere,
yes i can test it with a test light
factory alarm and everthing lights up fine but does not dim when i turn the key and try to start
Nothing happens when i turn the key
Well crank sensor for sure but you ruled that out and I highly doubt a cam sensor could...try searching google for ls2 no start or search for those codes in relation to your problem.
If you have not figured out your problem by tomorrow when I go back to work I will check Identifix for you and that should help out a lot.
Forget about the Crank Sensor for now. That won't keep the car from getting power to the starter.
Is this an auto or manual trans? If manual, trying pushing the clutch pedal ALL the way down to the floorboard and see if it cranks. You could have a bad clutch safety switch which would keep power from going to the starter.
The diagnostics that CO99Z28Vert posted should help you out. Like checking the starter relay. I'm assuming the theft light isn't flashing?
Ok I will check the relay. I made sure I pushed the clutch pedal all the way down. Cause I thought that may be an issue, didn't change anything.The car symbol with the lock is flashing until you yurn the key on, then it goes away also i just went outside to check some fuses and noticed its saying (trac off) and it has never said that before
