Burnt up a couple wires.
When I was changing my plugs on the passenger side, I noticed a two small wires wrapped in a heat shield that were burnt through because they had been sitting on a header primary.
It's just two wires one green the other is a tan color. There is a connection that is right at the bottom by the header and runs to the back of the car. When I started the car again my ABS INOP and ASR OFF lights came on.
What are the wires? I'm assuming they're something to do with traction control.
I cut off the same wires and connector off a junk yard car so that I can splice them together I'm just wondering if a splice in the line will cause the current in them to get messed up . I always get a headache when I'm working on wiring stuff so any help would be appreciated.
