Vibration @ 80mph+
Old 08-27-2013, 06:35 AM
ZL1Killa's Avatar
Default Vibration @ 80mph+
from idle to ~70mph car seems fine. 75mph~80mph+ the whole car vibrates. The rear view mirror vibrates so bad you cannot make out cars. The e-brake spring in the center console resonates also. When accelerating it is not as bad, but when holding a steady speed it seems worse and gets really bad when clutch in and slowing down.
I would think something rotational.
I've replaced:
*Both front wheel bearings
*axle bearings
Tires are brand new & balanced, even had them re-checked after they said they were balanced and I watched them.
Only thoughts are something relating to the transmission. I do have a cross-member mounted torque arm, so I know some more noise/vibration will come from this, but I know what I'm feeling is not normal.
Thoughts, ideas?
Old 08-27-2013, 08:34 AM
Brennen's01SS's Avatar
ID suggest getting the tires road force balanced. I went through this awhile back with new tires. Some suggested road force and it cured the problem. Most Cadillac dealers have them.
Old 08-27-2013, 09:26 AM
ZL1Killa's Avatar
rode with a friend in the car and the vibration wasn't as bad. thinking driveline angle and/or u-joints.
Ben Mynatt by my house offers it..will check out.
Old 08-27-2013, 07:36 PM
great421's Avatar
Another poss root cause to your vibration - the driveshaft.
Old 08-28-2013, 11:08 AM
ZL1Killa's Avatar
yep. It was checked when I bought it...but there is no telling.
Old 08-30-2013, 11:26 PM
QuicksterZ's Avatar
driveshaft,motor mounts maybe, wheels not torqued correctly
Old 09-01-2013, 10:42 AM
JDEP162's Avatar
im a tire noob, what is road force balance? sound like balance where its on a roller?
Old 09-11-2013, 11:17 PM
07kyeringt's Avatar
Honestly I would start with basics.. alignment. Otherwise it may be mounts or some bad bushings.
Quick Reply: Vibration @ 80mph+
