2001 ss shut off while driving
Try some jumper cables, see if it will start.
If you have another car or a friends car, drop their battery in, see if it starts. If it does, let it keep running and disconnect the negative battery terminal, if the engines dies you have a bad alternator. Get a new one and charge your battery.
Im not saying this is the problem, but the Crank Shaft Position sensor failing or acting up is just about the only thing that will cause an engine to just shut off out of nowhere while you are driving.
But since the starter won't even engage.......I would say its something else.
I done some research found one problem so far I pulled the steering wheel to pull the lock cylinder and found one of the vat signal wires coming broke from the switch will try to repair tomorrow but that still doesn't explain it dieing so I will get that fixed and continue from there and will update post as I go thank you all so far
If your MAP, CMP, OR CKP send different readings to the ECM that don't match up it will shut the door on everything and kill the car. Have you tried clearing any DTC's even if none are showing in between start ups?
Ok here is an update. one of my wires for the switch was broken fixed that problem now it will start but it still will not run there are no DTCS but I am getting a rpm signal in scanner when trying to start still testing things if you all have any advice let me know going to check spark and fuel now then will check sensors thank you all
Ok just finished replacing the fuel pump, and well fixed the problem so it was a mixture of two things my fuel pump and a vats issue the wire to the switch broke and my pump went out at the same time I greatly appreciate all the help and advice thank you all
