I can almost see my gas needle move.
I never thought I would be posting here about gas mileage buuut, my basically stock motor is getting around 15mpg on the highway w/o aggressive driving. I know it’s not a prius but I thought we get in the twenties? Even with the 3.42 gears it is only spinning around 2200 @ 70. It runs great but feels like there is a hole in the tank lol. Is this normal or should I look for something? Could it be the tune? Thanks. Brian.
Don't count out a failing 02 sensor(s)
They will totally KILL your gas mileage. And NO.....you will not always get an SES light or code until they are almost failed or really really in bad shape.
So get a scan to see how they are switching.......
One 02 sensor acting up will cut your mileage "close to" in half.
because there is no emissions here in FL and the guy i bought it from just straight piped it. its common here in FL i think a majority of the people I know first thing they do is eliminate cats and dont reconnect the o2 sensors, because the aftermarket pipes i have dont have a connection.
I may be wrong, but I think the only code the rear sensors will throw is to let you know you have a clogged cat. The rear sensors cannot change air/fuel parameters. Is just a light.
Also.....another thing that totally kills gas mileage is a leaky fuel injector. It's a pain to pull them and check them all, but if just one injector has sprung a leak your gas mileage will be TERRIBLE. And not always will you be able to hear misfiring or hesitation because they leak really bad under throttle and the combustion process can eat it up and hide it.
