Guide me to adjusting my passenger window .
Old 03-23-2014, 12:41 PM
ramairetransam's Avatar
Default Guide me to adjusting my passenger window .
Ive looked at the writeup on http://shbox.com/1/adj_window.html
Ive adjusted the window up so that its nice and tight but the back of the window isn't tight at all . Very loose and easy to pull a dollar bill out when the door is closed with the window up .
How to i adjust the back to make it water tight ?
Also when adjusting the top of the window , i want it tighter against the seal which way to i adjust the jack studs? clockwise or counter?
Old 03-23-2014, 03:27 PM
98boxer's Avatar
Did you accidently drill out the rivets that hold the window? If so make sure the bolts you put back in go right in the same place the rivets are in. Make sure everything is aligned correctly and that the tabs that push againtt the window are not overly tight.
Old 03-23-2014, 04:06 PM
Stock window.motor. not.the.original door
Old 03-24-2014, 01:40 AM
98boxer's Avatar
Remove the interior door panel look to make sure the car still has the original rivets that help hold the window mech. in place or you may just need a new window motor.
Old 03-24-2014, 06:35 AM
the door panel is off , ive adjusted the window up , i need to get it to tilt in at the top and how to get it tighter to the vertical part of the glass .
Old 03-24-2014, 07:39 AM
Save the manuals!
wssix99's Avatar
OK, We are missing part of the story here... Did this just start recently, has it gone on a long while, did you just have the door swapped?
If this has been going on since the door was replaced, then the adjustment you want to make is on the vertical track at the very back of the door. This controls the placement of the glass on that weatherstrip. (Once you are done, you may have to do some of the other adjustments over again.)
If this is recent, you could have another type of issue...
Old 03-24-2014, 07:49 AM
autogeek23's Avatar
im so glad there is a lot of insight on the window issue. good luck with adjusting. i have an issue with my driver window ill be fixing soon. this doesnt look too bad to fix compared to other issues including mine.
Old 03-24-2014, 08:21 AM
ShawnD's Avatar
Me too! I have got to get to work taking this thing apart. Window is "****-eyed" so not sitting flush at the top roofline or bottom sail panel. It's just a hair off but so damn annoying!
Old 03-24-2014, 08:24 AM
i bought the car and is was like this when i got it . ive just been dealing with it getting wet inside the car when i wash it , but decided to fit it .
The door motor is good no wear on the fiberglass mounting mounts.
But the door is adjusted higher. Thats what the pics are of . Its adjusted up tight but in the second pic is where its loose.
Old 03-25-2014, 06:41 AM
Tolley's94z28's Avatar
Are the little brass guides that bolt onto the top of the door adjust to push the window outward?
I know my explanation is hard to understand, but I had to adjust mine to keep it from doing exactly as you are describing. I think the original owner was trying to stop the window rattle when you close the door.
Old 03-25-2014, 07:45 AM
no those are for adjusting the window from rattling . Check the guide i posted , it tells you how to adjust but i need to know what way i have to turn the jack-bolts . Which is doesn't tell.
Old 03-25-2014, 08:09 AM
Save the manuals!
wssix99's Avatar
Hijackings thwarted.
Quick Reply: Guide me to adjusting my passenger window .
