humming noise when turning
Old 03-31-2014, 05:32 PM
countryguy1717's Avatar
Default humming noise when turning
My 98 z28 started making a humming, squeeking noise when turning. I only hear it on a turn 90 degrees or more left to right when going at slow speeds. I thought maybe the power steering pump but it doesn't make that noise when stopped and turning the wheels...
Old 04-01-2014, 12:14 PM
Save the manuals!
wssix99's Avatar
Maybe your wheel bearings?
Old 04-01-2014, 06:03 PM
That would cause the humming squeeling sound?
Old 04-01-2014, 07:08 PM
MTN_Z's Avatar
Wheel bearings can make all kinds of fun noises when they aren't happy.
Hard to tell without hearing it though.
Old 04-01-2014, 10:46 PM
Save the manuals!
wssix99's Avatar
Yes, they make different noises. It could be anything from a groan to a high pitched squeal. The tell-tale is that the frequency of the sound varies with speed and not engine RPM.
Old 04-02-2014, 09:46 AM
98ws666's Avatar
End links can groan like that.
Old 04-02-2014, 03:44 PM
interesting because I just swapped by driver side end links to master pro. While they didnt have two sets of masterpro at oriellys I bought a Moog end link for the pass side, but it wouldnt fit. So I ended up putting the stock end link back on the pass side.
Old 04-03-2014, 12:20 PM
98ws666's Avatar
Which side is making the noise?
Are the new bushings polyurethane?
How much did you torque the end links?
Edit: Maybe the stiffer new bushing putting extra pressure on the stock bushing? The new bushing holds firm, the old bushing probably mushrooming out and moaning with that extra resistance under sharp turns.
Old 04-03-2014, 12:37 PM
drivers side is poly, pass side is stock so rubber. The sound does seem to be coming more from the pass side, but also a little from the drivers side. I cant recall how much I torqued them. They didnt start making the noise until a week or two after I put the one new one on.
Quick Reply: humming noise when turning
