Threw a belt and coolant leak
I was driving home last night and noticed I lost my power steering. I limped a mile or so and parked it. I found the belt off and coolant had leaked all over the engine bay. I also saw that I was dripping a good amount of coolant into the parking lot. I got it towed home. Is there any way to know if I did some damage? If so, what are the likely results?
Super Hulk Smash
Your power steering cooler (which is in-line with the upper radiator hose) most likely gave out and started leaking. Although usually they fail into the coolant and mix PS fluid and coolant together. Sounds like yours failed outward and both coolant and PS fluid leaked out and your PS pump seized up and that's why the belt was thrown.
Thanks for the quick reply. I'm not sure if it changes things, but I just added an aftermarket AC which uses the main belt. I found the belt had been torn along one of the grooves which made me think something wasn't aligned properly. However, if it is the ps cooler, is fixing that major surgery?
And by the way, the vehicle is a 67 Chevelle that I dropped an 04 GTO LS1/T56 into (if that helps).
Your belt may have been a little loose, or your tensioner may be worn out. Your belt most likely jumped one of the pulleys and the edge of the pulley split your belt and tore it apart. You lost power steering because the pump wasn't being spun. I would check the pulley alignment with a straight edge between your compressor and the accessories on either side of it. I have read of people needing a belt 1" shorter than the bracket manufacturer suggests- the last three digits of the belt's part number tells you it's length 865= 86.5". You should be able to rent a radiator tester from a auto parts store and see where the leak is, the belt probly cut a hose but may have punctured your radiator.
Thanks guys. I couldn't find any power steering leak. I already ordered a belt that is 1/2" shorter. It got hot but not way up - temp gauge said 210-215. I was just worried about doing damage to the engine. I haven't had time to get under the car and even see where the coolant came from
Any ideas on where the coolant came from? I'm hoping my radiator didn't crack.
Also, I'm not running a power steering cooler. Maybe I need to get one? I've read some reviews that it's not necessary
When your belt came off it most likely cut a radiator hose, if have the coolant crossover hose going to your radiator(it's a small hose that comes off a small pipe connecting your heads) that would be my first guess since it's the smallest. You should fill your radiator with water(pour it down the top hose to fill the block) to find the leak, the tester I was talking about has a connector that replaces your radiator cap and comes with a hand pump, you only need about 12pounds of pressure to find the leak. After you replace the hose or fix the leak fill your system with antifreeze mix.
Thanks guys. You were right on the mark as usual. New belt and swapped out the main radiator hose and I'm back up and running. I also took a good look at the pulley system with the new ac setup and think that may have been the culprit. I shimmed out one pulley and it lines up much better now.
