Knock
Old 07-12-2014, 11:47 PM
HD22's Avatar
Default Knock
What's up guys I'm new to this an I have a 02 camaro ss that's been sitting for a couple months started her up drove it around for about a week... I filled up the tank within 15 mins ses light came on throwing a P0332 code ( knock sensor), the car runs fine doesn't seem like I'm loosing power or running sluggish, any idea if it's from the gas??
Old 07-13-2014, 02:21 PM
Crimsonnaire's Avatar
I assume you filled with 93 octane? Do you hear any pinging?
If you can get at the sensor, you should test its functionality with a multimeter and also make sure that it's tightly bolted in.
Old 07-13-2014, 02:52 PM
chrysler kid's Avatar
They can go bad from water getting into the engine bay and collecting under the intake manifold
A code for both sensors would indicate a vacuum leak
Old 07-13-2014, 03:48 PM
HD22's Avatar
Yes I filled up with 93 octane and no pinging.. I'm throwing a bank 2 the one closer to the firewall
Old 07-14-2014, 09:55 AM
RockinWs6's Avatar
Try driving it for a while before you do anything, it may just be wet and need to dry out.
Old 07-14-2014, 05:21 PM
dailydriver's Avatar
I found this out the hard way (i.e.; be REALLY careful when cleaning the engine with water OR steam!!).
Old 07-14-2014, 08:12 PM
HD22's Avatar
I took it out for about half hour drive an the ses light kicked right off....hope it stays off
Old 07-14-2014, 08:40 PM
HD22's Avatar
Thumbs up
Thanks for the help guys
Quick Reply: Knock
