First time engine/trans removal
As the title states I plan on removing the sub frame, engine and trans from the car through the bottom. I'm looking for helpful tips and suggestions since this will be my first time ever doing it from the bottom side. Should I remove the hood and front bumper?, what should I use to set everything down on and be able to roll it out from under the car?
Pretty much yeah, I won't be using a lift I'll just be using an engine hoist to raise the body off of the subframe. Its all ready to go right now, I just don't want to start pulling the body off the subframe and find out I need to remove the hood or front bumper for clearance to get the body high enough
I did it with just a pair of floor jacks. Removed the hood just to give me room to work, it wasn't necessary. You don't need to remove the front bumper.
The hardest thing for me was finding all the connected wiring, so go slow when you start to lift and keep checking- as you go.
I didn't use any ramps or anything on the back wheels, they were right down on the ground. Took off the front wheels and lowered the K-member down on to some furniture dollies and then lifted the body back up once the bolts were out.
I usually leave the front wheels on and just use one furniture dolly under the trans.
I've done a few like that now, if inside I hang the front onto rafters if possible.
Lower the air pressure on all tires involved and the car is very stable, open and closing doors, climbing in half way to get tools/parts I left on the floor ect. I guess it looks sketchy but in person its very stable.
I will admit that I almost caused a few traffic accidents with that one, everyone driving by slowed down a lot!
