accidently drilled a hole in the top of my gas tank
I have a 2000 pontiac t/a ws6. I cut a second trap door next to my gas lines on the left side or the fuel pump assembly.I made another plate to fit over the hole I cut.I accidently drilled a hole in the highest part of the tank. I formed a thin metal plate over the hole and used JB weld to put the plate in.
After I did this I was wondering if Jb weld is gas resistant. I guess I could run half a tank of gas all the time.So what do you guys think?
I was once screwing something down in one of my old hondas and when I took the screw out I could smell gas, so I just put the screw back in and never had an issue, the car was either flooded or wrecked (can't remember which one I did it to) a few years after the incident with the screw.
From my experience, regular JB Weld won't seal a damaged gas tank. It will seep around the edge of the repair. But JB Weld makes a product called "WaterWeld" that's specially formulated to work on gas tanks. It works well.
You may be fine though since the hole is on the top of the tank.
