Is metal shavings in the exhaust ok?
There is what sounds like little pieces of metal in my driver side exhaust pipe where the back of the stock pipe after the cat(oe exhaust manifolds)meets the cat back at the flange. I am guessing my cat is starting to fall apart. Do I need to address this is, can any particles get sucked back into the motor? Thank you. Brian.
The particles can be sucked in if you have a big *** cam and the cats are higher than the heads, maybe.
Yes you need to address it. Not because the particles (they'll likely never get into the engine), but because the cats will clog up. Throwing off O2 readings, AFR trims, and the added back pressure are all bad for your engine.
Fix it sooner than later. My buddies C4 vette dumped his big cat few weeks ago. His car kept cutting off cause it was choking so we just gutted it after finding it was totally compacted and falling apart
Not an emergency, but important to fix as soon as possible (even it that means gutting it). A replacement aftermarket cat is cheap, I go mine for $70 installed from a local muffler shop. Call around and see what they can do for you.
Yes. A damaged cat can cause gas milage to drop along with power. Your car has pre and post cat o2 sensors, so when the cat starts to lose efficiency it'll throw a code. I'd start by making sure your cat is actually the source of the rattle.
Depends on how you buy it.
LS1Tech Administrator
Received 1,492 Likes
