Where does this line go to?
Old 06-24-2016, 08:00 AM
tnmotown's Avatar
Default Where does this line go to?
It's kind of a bad picture, but it's a hard plastic line that is routed in my "wire tuck" lines. It's some sort of vacuum line I'm thinking. It goes from a port right near the PCM and seems to go towards the battery area? Anyways....it was very brittle and when I moved it around it broke. Just curious if I can cap it off. Thanks in advance!
Old 06-24-2016, 11:05 AM
Majestic9C1's Avatar
mines hooked up to a T fitting in front of the PCM... no idea what it does but its still hooked up..
Old 06-24-2016, 11:22 AM
tnmotown's Avatar
Yep, I believe that's the same one. I'm not sure either, but the car still seems to run ok. Just curious where it goes....
Old 06-24-2016, 01:40 PM
Spartan7's Avatar
It's for the HVAC system. Goes from the reservoir on the passenger side frame rail up to the check valve near the PCM.
Old 06-24-2016, 03:06 PM
tnmotown's Avatar
Oh ok, my HVAC is long gone lol. So I assume I can just cap it at the check valve near the PCM?
Old 06-24-2016, 05:21 PM
dailydriver's Avatar
^^^Even your complete HEATER is gone, core and all (TOTALLY trailered drag ONLY car??)?
Because, IF you still want heat in the car that tube has to be connected, or the HVAC heater switches will not work.
Old 06-24-2016, 05:23 PM
tnmotown's Avatar
Yep heater is gone too, it's 110 here in the valley so I never need a heater lol.
Old 06-24-2016, 06:18 PM
My AC is gone too but I still have the heater so thats why I left mine plugged in.. (tucked under with the rest of course)
Old 06-24-2016, 07:37 PM
Spartan7's Avatar
The vacuum source is for the directional doors in the HVAC box only. So if it's gone, all that stuff can go. The only thing you need is a vacuum cap on the intake where it used to be hooked up.
Quick Reply: Where does this line go to?
