Turn Signal Flashers
As of lately when I use my right turn signal, the light stays solid and doesn't blink. I know the bulbs are working because I stood outside while the the right turn signal was engaged and I noticed that both the front right and back right turn signals light up, they just don't blink. Thankfully my left turn signal works normally. This is most likely a problem with a turn signal relay right?
Save the manuals!
If your hazard lights work, then the problem is definitely your turn signal flasher. (This rules out anything else it could be as the hazard circuit shares a number of components.)
BTW - Switching stock flashers may not work because the thermal heard flasher expects the full load of all the bulbs.
Save the manuals!
There are two flashers in the car. One high power one for the hazards located to the left side of the steering wheel and one lower power one for the turn signals, located to the right of the steering wheel.
So about an hour ago my front right turn signal stopped working. The bulb burnt out and the rear turn signal would still stay constant...looks like I gotta replace a bulb now too
Yeah I checked it again this morning, my daytime running lights are fine and my turn signal bulb is out. I can see condensation within the turn signal housing. I guess I'm gonna have to replace the bulb and then find a way to keep water out of the housing
Save the manuals!
That condensation is problem #1 and is 99% probably why the bulb is having problems. If you press on the lens, you may reveal a crack in it. (This is common and allows moisture in.) Water + Hot Bulb = Blown Filament or Exploded Bulb You might even have some corrosion in there causing issues...
So, ^ Check this first and see if you need a new lens. Some yellow lens tape will look ghetto but can get you back in business while you await for a new one to arrive.
Your DRL filament in the bulb IS your turn signal filament. So - If your DRL works and your turn signal does not, then you likely have a flasher issue, too. Did you do the hazard test, yet?
If your headlights are on and the light goes dim when your turn signals are on - this is normal for a bad flasher. The DRL module is driven by the flasher and will turn off your parking light in anticipation of a flash.
If your parking light is out when the headlights are on, then your parking light filament is blown out.
consider getting LEDs so they dont heat up the lens as much as stock bulbs. I was burning out my turn signal bulbs every few months due to cracked lenses. Ive since replaced my housings, switched to LED bulbs, and havent had any problems with my bulbs anymore. If you do this, you will have to change your flasher too.
I bought a new set of bulbs and I'm getting a new flasher soon. I'll find the culprit soon! And I heard that drilling a hole on the bottom of the assembly was a good way to drain the turn signal assembly of water in case it floods so I was thinking of doing that too
Hey, turn signals went haywire on me a while back, replaced the front turn signal bulbs and housing for the bulb. lens is cracked but no moisture inside, and the reverse lights are tied in the same system and obviously don't work either, where do I start, how do I do this, much appreciated! I already tried the fuse too btw it just keeps blowing as soon as I plug it in.
