How do you stop side view mirror shake?
My drivers side view mirror shakes whenever I go over bumps or rough roads.
Is there a way to tighten/stop the mirro shake?
Thanks in advance!
Thanks in advance!
Originally Posted by ACW
There are some nuts that hold the side rearview mirrors in place, hidden behind the interior door trim panel. They should be tightened to 12 N·m (106 lb in).
My driver's side mirror shakes too (if you press on the top left and bottom right it rocks right on the perpendicular axis). I compared it to the passenger side and it looks like the piece that bolts on the mirror and motor is broken/missing a screw.
I have the same problem. I took the mirror off, and discovered the cause was a pot metal rib/brace that connects the top mounting stud to the rest of the mirror assembly had cracked. I tried to epoxy it back together, but after about 50 miles or so it broke again. If your problem is the same as mine, I think the only fix is to buy a new mirror.
I had the same problem. I tried to tighten the nuts on the inside of the door panel and that didnt work so i took it completely off and realized there is more nuts inside the mirror so i tightened them and not a porblem since
