2004 Dodge Neon, check engine light is on
Old 04-13-2006, 09:48 AM
Dean-o's Avatar
Default Help with inspection...
My girlfriend has a 2004 Dodge Neon and the inspection is out, but the check engine light has been on for some time now. I don't know if it is a random code or if there is a problem that needs to be fixed. The car runs fine, but it won't pass with the light on. Can anyone help? Know anywhere I can take it?
Thanks.
Dean
Old 04-13-2006, 10:01 AM
Strini SS's Avatar
Thanks.
Dean
I would run it by Auto Zone just to see what the code is?? could be somthing simple..
B
((((((Administrator))))))
CRAGER's Avatar
You can try to uplug the battery and the PCM fuse in the engine bay and wait a few minutes. That will clear it unless the problem is still there, it might take awhile to throw it again.
But I'll ask around later on today.
Peace,
Craig.
Old 04-13-2006, 10:23 AM
Dean-o's Avatar
OK, thanks.
Old 04-13-2006, 11:23 AM
SLPformula's Avatar
Find out what the code is fix it then inspect it. once you clear the code with a scanner it has to see a problem twice in the sytem to throw a check engine light. But you cant just clear the code its still gonna show up on there machine if the problem is still there. Find out what code it is and fix it.
Old 04-13-2006, 11:26 AM
had20z's Avatar
Peace,
Craig.
x2.....
Old 04-13-2006, 12:43 PM
Moderator
BizZzatch350's Avatar
Originally Posted by had20z
x2.....
When they try to inspect it, its going to come back not ready and they cant inspect it.
Old 04-13-2006, 01:32 PM
Dean-o's Avatar
I think if it is a random code, it will clear and then it has to be driven for at least 50 miles to be ready for the inspection. At least that is what I have learned. Also, Autozone said they can check the code, but they cannot clear it! So I'm doing the battery and see if it stays out for 50 miles and then get it inspected.
Old 04-13-2006, 03:07 PM
JETG's Avatar
Dean
Did I fall on my head and bump it ?? Your girlfriend ???
J
Old 04-13-2006, 04:11 PM
Onyx Z's Avatar
From what I understood from the inspector of my car, if it has 3 or more "NOT READY" codes during the inspection, then it will fail. It was a re-inspection, so this may only be true in that case.
Old 04-13-2006, 04:23 PM
Dean-o's Avatar
Originally Posted by JETG
Dean
J
No, I am divorced. I moved out 3 months ago and got my own place. So don't bother checking your skull for lumps... he he!
Old 04-13-2006, 04:50 PM
JETG's Avatar
Dam holy shiet, I move away and all hell breaks loose.
Hmm okay, well shoot me a pm with your number, I want to make sure I have the correct number
Jet
Old 04-13-2006, 05:04 PM
rayosequis's Avatar
I have one of those scanners that they use at Autozone, and you would be welcome to use it and clear the code if you like. If so, send me a PM.
Quick Reply: 2004 Dodge Neon, check engine light is on
