Howling noise
Old 04-14-2006, 03:30 AM
LSWannabe's Avatar
Default Howling noise
I've got a howling noise from the engine compartment that I only really notice during low speed turns. (1st and 2nd gear) It sounds like a eaton blower (which sucks because it's not) but I suspect it's my power steering pump. In order to see if this is the problem, can I run the car without the serpentine for a short while?
If I pull the belt off I'll lose power steering and the alternator charge, is that everything?
If it is the PS pump, should I get a new stocker or look at a possible aftermarket pump? I doubt it would be worth getting this one rebuilt.
Old 04-14-2006, 10:35 AM
conan's Avatar
You will also loose the water pump with the belt off. Do you still have A/C in the car. Might want to check that as well, Mine started squeeling on me before I removed it. As far as running it with out the belt it should be fine might want to do it after it's completely cooled down.
Old 04-14-2006, 11:53 AM
...with cheese.
Armageddon's Avatar
PS Pump, do not run the car with the belt off.
Old 04-14-2006, 01:59 PM
FunkyTownFBody's Avatar
Yeah I vote powersteering pump. You can get used ones pretty cheap if you look around, but I'd probably just get a new one if it were me.
Old 04-14-2006, 02:28 PM
conan's Avatar
What would it hurt to run the car with the belt off??
Old 04-17-2006, 12:41 PM
conan's Avatar
TTT anyone have any info on running the car without the belt??
Old 04-19-2006, 09:55 AM
MarkuzLS1's Avatar
No belt means no water pump. It would overheat and boil over pretty quick.
Old 04-19-2006, 02:40 PM
B.W.'s Avatar
Without the AC belt you'll be fine. DO NOT run the car without the larger belt, no water pump means your car will overheat quickly.
Old 04-19-2006, 02:59 PM
conan's Avatar
I understand the no water pump but with a completely cold engine it would take a min or so to reach overheat temps.
