Bad Coil Pack?
Bad Coil Pack?
Ok so my car appears ot be missfiring down low, under 1500 RPM's typically not as bad as before its pretty minor. When driving it gives little/no problem,, and its no longer counting misses. but the motor and car are shaking more than usual especially if i let off the gas around Lock-up (auto) How can i test the coil packs nd find which one(s) is/are messed up? i have a 2002
buddy of mine said that happened to a vette @ his local shop he had no idea how to check it they left it car ran fine just idled kinda bad. Let me know fellas if ya can i really need this!
Originally Posted by Shinerbock07
sounds like bad plugs/wire/coil pack something simple like that....IF not that than a def. sign of a vacuum leak
What would be a vaccuum to check though? i havent pulled anything off this car so it wouldnt be the intake manifold or anything
1 Post
brand new plugs and wires, will double check motor mounts but the miss can be heard and felt
im assuming this problem didnt exist before the new plugs, how long afterwards did it start?
Well keep us updated, im curious to know what it is
Originally Posted by akZ28
Have you gotten an SES light yet?
Originally Posted by camaroextra
Have you checked them since you have put them in?
You should try pulling off each coil pack one by one and starting it if it gets worse then you know that coil is good if it doesnt change when you remove one then you probably found the problem.
I dont really understand this method sorry please explain
nd as for vaccuum leaks what are all the vaacuum to check PCV, Brake Booster and intake?
So To The Top everyone....
What are symptoms of a bad coil pack(s)? Whats the best way to check?
The car after heavy use and then a good brake seems to surge a little. drops under 500 RPMs and then goes right back to normal with a very minor miss that the computer does not detect- not even when loggin it in. Does that sound more like a vaccuum leak by chance? What would be best to check
Thanks everyone i really need answers to all of the above!
anything electronic, usually the computer should pick it up, if its this bad, the computer would flash the ligh telling you of misfires, So for it not to pick it up, has to be something physical, like mechanical not linked to the electronics per say. im guessing you did a search on bad coilpacks? its rare one goes.
how many miles are on ur car? this doesnt sound like a fuel or spark problem. sounds more like an air problem. the PCM is VERY good at picking up improper fuel or spark. but not nearly as good as finding unwanted air. or it could be as simple as this... if u have over 35000 miles, u might want to do a seafoam treatment. after time, ur intake will get gunked up with PCV gases and it will make the incoming air tumble and make ur car run like *** down low. such as coming to a stop sign or light and taking off from a light or sign. try the seafoam, u have nothing to loose. however, if u do the seafoam, change the plugs AFTER cuz it will make ur plugs useless after its done.
I had something kinda like what you are describing right after I installed a Vigi3600 stall. As I would slow to a stop, it would pull the idle down so low, that it would sputter and want to stall. I just raised the idle up a bit and the problem went away.
ANYBODY symptoms? Trying to trouble shoot here could most likely be one of the two from my asusmption but iw watn to knock out the most apparent problem and cros my fingers
