Front end creak
Old 04-23-2006, 11:51 AM
huntmoneyls1's Avatar
Default Front end creak
I have a 96 Trans am and whenever I turn the steering wheel either way I here a creeking sound from the front end. Either way I turn it its the same sound. It still drives straight just the noise. I was wondering if anyone had any insight to this before I have to jack it up and start looking for problems.
Old 04-24-2006, 02:26 PM
wamp42's Avatar
I have this problem too on my 98 Formula.
Old 04-25-2006, 05:32 AM
leadfoot4's Avatar
Bad ball joint, maybe... The factory parts aren't greaseable.
Old 04-25-2006, 11:26 AM
wamp42's Avatar
So they arent greasable. I was kind of wondering if that was it, but I guess its not possible.
Old 04-25-2006, 03:17 PM
Dal1as's Avatar
Likely it's your sway bar bushings. Try greasing them. I have a similar issue. Greasing them this weekend.
Old 04-25-2006, 03:54 PM
todddchi's Avatar
Does it do it 100% of the time, even after driving for a long time?
As the rubber parts start to dry out a little you can get some of this, but it should go away after a few miles. If it sticks around then you should probably get under there and take a look at everything in the front suspension, ball joints, strut mounts, sway mounts, etc.
Old 04-27-2006, 09:54 AM
ya it does it almost all the time, its only really noticable tho if you really jerk the wheel from side to side at a slow speed.
Old 05-10-2006, 12:01 AM
98hardtopZ's Avatar
haha, mine is doing the same, upper ball joints. its annoying as hell isnt it? i hate pulling into friends driveways and restuarants, it sounds like im driving a pos.
Old 05-11-2006, 01:29 PM
Dal1as's Avatar
Just found out my issue is the lower balljoint. Will get it replaced soon enough.
Quick Reply: Front end creak
