HELP! my car is acting strange
Old 04-28-2006, 07:08 PM
iwantanls1's Avatar
Default HELP! my car is acting strange
So i pulled into my apartment today, turned the car off, no problems. I go out and start it up tonight and it barely turns over. It turned over on the first try, but the rpms wouldn't go up, so it took about 10 secs to make up its mind and decide to stay running. I put it in gear and take off then come to a stop sign. I come to a stop and the rpms dive dangerously low to around 350-400. I drove 3 miles down the road to where I was going and it did this the whole way. When I stopped in the parking lot, I put it in neutral, evetually the rpm's did go up to around 700-800, where they should normally be, but it took about 25 secs to do so. Luckily the car did stay running and didn't stall at all, but I'm still pretty worried. Any idea what this could be?? help would be greatly appreciated!
Old 04-28-2006, 08:14 PM
bigbadblackws6's Avatar
my car is doing something similiar. but i dont know what it is.
it is gay tho
help would be appreciated.
steve
Old 04-28-2006, 08:23 PM
12Gauge's Avatar
Im also having the exact problem. Anyone out there know what it could be?
Old 04-28-2006, 08:34 PM
01MMMZ28's Avatar
Don't quote me on this, but someone once told me that if something like this was going on it could be some type of idle control sensor.
Old 04-28-2006, 08:48 PM
Shallow Bay's Avatar
IAC (Idle Air Control) valve?
Old 04-28-2006, 09:03 PM
FHAWKer's Avatar
Mine does something similar every now and then. When I start it, it only reaches about 500 or so RPM then dies immediately. Usually takes three starts to get it to reach 7-800 and idle normally. My guess is the security system, does the security light come on when this happens to you?
Old 04-28-2006, 09:17 PM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
mine has done that before, but only due to battery being removed the car had to re learn everything....
Old 04-28-2006, 09:47 PM
iwantanls1's Avatar
any chance its a dirty MAF sensor? I didn't notice the security light on, but since I wasn't really looking for it, I can't say that it was off either.
Old 04-28-2006, 10:31 PM
Ws6man2000's Avatar
go get it scanned at autozone!!!!!!! try re setting the pcm see if that remedy's the problem for a little bit and if it doesnt you def have a issue
Old 04-28-2006, 11:47 PM
i got mine scanned and here is what it says and the codes i got form it....
P0102 MAF circuit low input
P0135 Bank 1 sensor 1 heater circuit malfunction
P0155 Bank 2 snesor 1 heater circuit malfunction.
anyone know what this is? this it getting really gay.
Old 04-29-2006, 12:14 AM
Ws6man2000's Avatar
i dont know what that means but seems like a dirty maf probally, i cant remember what ppl use to clean those do a search on how to clean maf i bet that might fix your problem or search for that code number
Old 04-29-2006, 12:16 AM
Ws6man2000's Avatar
https://ls1tech.com/forums/showthrea...ighlight=p0102 i found this , jsut type in that code in search you will find a lot of help through that i found several dozen threads
Old 04-29-2006, 12:24 AM
sandro arellano's Avatar
use non-chlorinated brake cleaner, thats what the gm mechanic told me to use and it works great.....
Old 04-29-2006, 02:16 AM
iwantanls1's Avatar
let me know if it improves after you clean the MAF...I've very interested to know. people say rubbing alcohol with a q-tip works good too.? I would clean mine tomorrow but its finals week and I really don't have any spare time.
Old 04-29-2006, 09:44 AM
Copy & Paste Moderator
VIP1's Avatar
P0102: Dirty or damaged MAF or wiring
P0135: Replace the Driver-side front O2 sensor, its heating element has failed
P0155: Replace the Passenger-side front O2 sensor, its heating element has failed
Old 04-30-2006, 12:59 AM
Corvetteman78's Avatar
Check the obvious before you go into code checking. check your battery voltage, alternator output, and battery connections. The barely turning over usually means low primary voltage, usually caused by a bad connection to the battery. Look at your ground connections at the battery and engine block. Low voltage can mess up a lot of things. The slow turning over is a signal of primary trouble, your computer will not work right with low voltage and amperage. Have fun!
Old 04-30-2006, 03:36 AM
Dave C's Avatar
I had a similiar problem - I talked to a R & D guy from Rousch Racing about it. I'm presuming you're not getting an engine light as well. Oil from a K & N air filter on the MAF will cause this situation - they referred to it as a rolling idle. Your MAF could be going away as well and as mentioned earlier your throttle position sensor could be shot.
Old 04-30-2006, 11:31 AM
iwantanls1's Avatar
thanks for the help everyone....i'm gonna clean the MAF and go from there.
Old 04-30-2006, 12:36 PM
racer88's Avatar
I had a bad plug wire that made my car stumble and stall after startup. How old are your plug wires?
