Seafoam
Old 05-13-2006, 01:28 PM
1QuickBlkZ28's Avatar
Default Seafoam
I bought the Seafoam but I need to know where the PVC or Brake booster line is so I can run it through the engine.
Old 05-13-2006, 01:43 PM
conan's Avatar
Look at the brake fluid reservoir and you'll see a big vac hose going to the back of the intake remove from the brake booster and let the engine drink it up.
Old 05-13-2006, 01:47 PM
Originally Posted by conan
Look at the brake fluid reservoir and you'll see a big vac hose going to the back of the intake remove from the brake booster and lut the engine drink it up.
is it the hose connected to the big circular thing under the thing with the blue stuff in it?
Old 05-13-2006, 02:12 PM
conan's Avatar
The hose that he is removing with the pliers
Old 05-13-2006, 03:27 PM
What about the Deep Creep in the throttle body? Do I spray it through the MAF or remove the MAF and spray it directly on the TB?
Old 05-13-2006, 03:32 PM
tc3
tc3's Avatar
directly through the throttle body..
Old 05-13-2006, 03:37 PM
So I have to remove the air box and accordian thing to get the throttle body and just spray it?
Old 05-13-2006, 03:54 PM
conan's Avatar
Take the lid and MAF off as one part.
Old 05-13-2006, 06:00 PM
1/3 in the brake booster line, 1/3 in oil crankcase, 1/3 in gas tank, and half a can of deep creep into the TB. It really didnt smoke that much only the first 3 times I WOT'd it, the first cloud was moderate, the second was alot less smoke, and the third, was barely noticeable. I'm going to let the car sit for 30 min and then change the oil. Can anyone tell me where the oil pan is on the underbody of the car, and also where my spare tire jack is to lift the car?
Old 05-13-2006, 06:26 PM
radz's Avatar
the oil pan is directly under the engine, you will find you a bolt just take it out to drain the oil. your jack should be in your trunk on the right side you will have to take a panel off
Shallow Bay's Avatar
http://www.installuniversity.com/ins...oil_change.htm
also where my spare tire jack is to lift the car??
you can see it in figure 3
http://www.installuniversity.com/ins...ease_fix_2.htm
Old 05-14-2006, 04:47 PM
Pewterpower's Avatar
Those are some ugly-*** hands!!!
Old 05-15-2006, 02:15 AM
BIG BAD BLACKSS's Avatar
Dont forget to replace the kaneuter valve after a seafoam flush or you can break a flamshooter checkvalve. Trust me when i say you dont wanna break the flamshooter valve! Ended up costing me more then you can imagine.
Old 05-15-2006, 02:17 AM
ChicagoTransAm's Avatar
Originally Posted by BIG BAD BLACKSS
Dont forget to replace the kaneuter valve after a seafoam flush or you can break a flamshooter checkvalve. Trust me when i say you dont wanna breal the flamshooter valve! Ended up costing me more then you can imagine.
Good point BigBad....
