Crazy loud squeeeeeeeking
ok... when I turn on my AC... somewhere under the hood it just constantly squeeks to high heaven... it isnt the belt cause I just changed that... help
need more info to be able to help you out dude.. listen closely to the area where it would be at and try to pinpoint where its coming from. also, check and see if you belt is straight. if a pulley is out of alignment, it could cause a horrible squealing noise.
Def sounds like a belt squeeking... but I just replaced the damn belts..... but I will try the brake cleaner... with it runnin... it isnt gonna shoot up in my face is it?
99 times out of a 100 if it squeels it is the belt ,recheck length,if it still does you mite have a bearing starting to sieze in something, remove belt and spin all pullys and ck them
