How to replace RH Blinker bulb?
Old 06-10-2006, 08:06 PM
mikesz28rocks's Avatar
Default How to replace RH Blinker bulb?
Hey guys, how do you remove the blinker, parking light assembly from the car to replace the blinker bulb? I know its only the bulb because the LH side works fine and the the RH indicator just stays lit telling me most likely its onle the bulb itself, but I cant figure out how to remove the assembly? If you can help me out that would be awesome.
Thanks guys
Old 06-10-2006, 08:20 PM
Brandon Boomhauer's Avatar
there is a little access hole under the nose of the car
2 10mm bolts and a little "flap" opens up and you can reach in and find it.
clean the socket out and put some dielectric grease in there before you put the new bulb in.
Old 06-10-2006, 08:23 PM
Thanks man but I think that might be for t/a's, I have a camaro. Thanks much for the help though.
bmfcamaro's Avatar
take out the headlight. its way easier. three bolts. i can actually reach behind the headlight and change them but im not sure about your car.
Old 06-10-2006, 08:26 PM
If your remove the headlight wouldnt that screw up the alignment of the headlight? I tried to reach behind it but the bulb assembly is on top directly underneath the headlight asembly.
Old 06-10-2006, 09:05 PM
ArrestMeRedZ's Avatar
Camaro has the access panel. Look on the underside of the fender just in front of the right tire. There are the two bolts and flap that Brandon mentioned. It should be easy to get to with that flap opened up, but as I recall, doing the other side, you have to feel around a bit.
Old 06-10-2006, 09:28 PM
ApacheDrill's Avatar
I can do mine from the top to, but if you removed the headlight align it on the garage door..
Old 06-11-2006, 11:35 PM
Jakson's Avatar
I took my headlight out, they need to be aligned again. It was still easier than tryin to reach under the headlight, my forearm got scratched to hell from the alignment bolt tryin to get the right bulb back in, so i took the headlight out and it was so nice. Just remove the headlight with the 1 bolt and just align them after you reinstall it.
Old 06-12-2006, 12:34 AM
98hardtopZ's Avatar
theres only one screw holdin that headlight in? what are you guys talkin about messing up your alignment? ive taken both mine out for the whister mod and put em back in and there fine? i changes my driverside turn signal bulb once i got hte driver side headlight out...that one screw and it slides to the left...
Old 06-12-2006, 12:53 AM
Jakson's Avatar
Yeah mine were held in by one screw as well, but my 2 headlights were different. The right side one just had plastic "sliders" where they slid into the metal plate behind the headlight, but the left side had 2 metal ones that were attached by a screw. Im not sure how they got out of alignment, maybe they werent aligned to begin with.
Old 06-12-2006, 02:32 AM
2002_Z28_Six_Speed's Avatar
I took my headlamp out and it did not mess up the alignment. I would rather change it standing then trying to crawl under a car as low as F bodies.
