Replacing door hinge bushing?
My driver's door creaks/pops when opening and closing due to a work hinge bushing. I can see the worn piece. It looks like just a thin metal bushing, but it's cracked and a section is missing.
Anyone service one of these?
Ben T.
Ben T.
I believe GM makes a full kit for those for about 80 bucks or so... maybe some one will chime in with the part #, if not I will look for ya when I get home unless you find it before then. One of the more common trouble spots on F-Bods.
Thanks for the response!
Glad to know others have this problem too. I've had this problem since I first owned my LS1 car (bought 2nd hand), and lately it's been getting to me.
Please get me a part number.
Ben T.
Ben T.
Ive never done it on the camaro, but the hinge pin bushings on my S10 have gone out before. Not too hard to do yourself (helps to have a second person), you can get the correct ones for the S10 at Oreillys for 5-8 bucks if I remember correctly. Check Oreillys before you spend 80 bucks on a dealer kit
Theres a thread about this... Let me find it.
Edit: Here it is... https://ls1tech.com/forums/appearance-detailing/443737-door-hinge-question.html
Charging, there are two posts in the above theread you directed me to by ME still asking for help. I've already seen that link and it's not a fix. I've tried to rotate the bushing to the "good" side, and that works nicely for about a week and then the creaking comes back.
I was looking for a complete fix.
Ben T.
Ben T.
