Banging noise
Banging noise
i just bought a 99 TA about 3 weeks ago and i didn't notice this noise until 2 days after i bought it. when i take off from basically a dead stop there is a banging noise and it gets worse when taking off around a corner. it only happens when i accelerate pretty good (not just WOT). i've heard it could be a tranny mount but i checked that and it isn't worn real bad or cracked. the noise seems to be coming from the rear, but i also started hearing a similiar noise from the front it seemed like. Any ideas??
another noise i just noticed was when i am driving around 45+ mph and hold the gas there is a whining noise while cruising, but if i let off the gas completely the whining stopped. i thought it could have been the serp belt but i changed it and that didn't help. Any ideas on this one??
well for the bangin noise...if it does it around a corner its probably your torque arm mount..but then again if its makin a bangin noise in the rear it might be your transmission mount is was for me made the same noise your talkin about.
nope not yet, but would it do that only when i am on the gas, b/c i thought that it might be the rearend but it stops when i let off the gas and am still rolling???
It sounds like a rear axle gear noise, from your description. Most gearset noises I repair are from just like yours- noise when accell and none when coasting. Most commonly backlash adjustment on gearset.
how would i fix that??
Originally Posted by burnrubr88
well if i end up having to replace the gears anyone have any opinions on whether to stay with 3.73's or go back to 2.73's???
I have the same problem, and figure it's the TA or the eroded jouncers (bump stops).
I checked the tranny mount and exhaust system, and found no issues.
Only does it on HARD accelerations, like a thud, thud, thud. Don't think it is the rear diff or u-joints!
I would recommend taking a closer look at the tranny mount and the torque arm mount. On my 96 T/a I would have bet you money the tranny mount was fine, I pulled it apart and found out that the rubber was worn on the inside and weak. Replaced it and the clunk was gone.
I had the rear end noise as well and someone advised me to flush my rear differential fluid, which would have helped had it not been for the fact that my rear end was worn out. I just found out that the bearings were bad, and there way metal shavings everywhere. I would check to see if your rear end has not gone out as well.
