replacing the seatbelt holder on side of seat
Having some Seat Problems.
the seat belt holders on the side of my seats broke
so they are all up in your neck. Not comofortable at all.
Is there a place to order these from? Should I go to a dealer?
Eventually I just need to get a new drivers seat.... grey leather.
anyways, thanks for any help
Originally Posted by JoeyAnderson
mall parking lot if someone leaves their car unlocked, etc...
thanks guys i'm swinging by the dealership later today. appreciate it.
that and a knew FOB key - 77 bucks... jeez.
should be here wednesday, had to order both parts.
Is it hard to unattach the seatbelts from the floor to get the restraint on?
Help - Can't get the Seatbelt off - any ideas?
Well - i'm trying to replace my seatbelt restraint - but I can't get the seatbelt unattached from the floor to get the new one on....
I took the plastic cap off to get at the star bolt - I have the proper size, but the damn thing is rusted and won't turn to save its life... after 10 mins of trying to get it off to no avail i've given up.
I don't have any power tools - was trying by hand.
my other option was to take a saw to the restraint and make a place where I can slip the belt through that way...
Go back to the dealer and get the convertible seat belt clips. They are shaped exactly the same as the coupe clips, but have a little slit molded into them so you don't have to unbolt the belt.
Or do the BFP mod on that bolt.(Get a big ******* pipe and slip it onto your ratchet for more leverage).
Don't be offended...but did you try Blaster or WD-40? I had to replace mine but it came out with little effort. I was going to cut mine(because I'm lazy) but the bolt was easy so I did it right. There's no safety issue, it's just cosmetic/comfort so cut away if you have to.
yeah I sprayed some wd-40 on it and left it sitting.
i'm gonna try again later tonight when it's not 95 degrees outside.
thanks for the idea though!
Originally Posted by Avengeance
LMAO..
When I read the title I pictured some guy sitting in his car wrestling around not able to get the seatbelt off.
Sorry.
Sorry.
But yea, I suggest you increase your torque exponentially and BFP it
Seriously, take a hammer and hit the head of the bolt straight on a couple of times. It will loosen up the rust and allow you to get it broken loose. That comes from years of working in a salvage yard. I'm rust's worst enemy.
