NEED HELP QUICK: brake booster hose/sea foam
Old 07-28-2006, 05:26 PM
LS1Aggie09's Avatar
Default NEED HELP QUICK: brake booster hose/sea foam
Hey...i have been trying to get my brake booster hose off for about 15 minutes, and i cannot get the damn thing off. Anyone have any suggestions? The piece that it is connected to wobbles a bit so im afraid to pull too hard and brake the peice thats on the booster. How can i get the dang hose off?
Old 07-28-2006, 05:42 PM
taintedmeat's Avatar
Grab it and twist on it. Use a pair of channel locks maybe.
Old 07-28-2006, 05:58 PM
LS1Aggie09's Avatar
i already tried to do that....its not even really wanting to turn at all...
Old 07-28-2006, 06:09 PM
LS1Aggie09's Avatar
no input whatsoever?
Old 07-28-2006, 06:24 PM
LS1Aggie09's Avatar
well **** on it...takin the can back
Old 07-29-2006, 12:55 AM
Shallow Bay's Avatar
I also had the same problem and thought for sure I would break the little piece the brake booster hose is connected to. I ended up using a screw driver to pry it off while constantly pulling from the other end and it finally came off. It took awhile the first time but once the hose has been off a few times, it’s much easier.
Old 07-29-2006, 06:59 AM
LS1Aggie09's Avatar
ok...ill try again i guess...thanks
Old 07-29-2006, 08:26 AM
YellowMonster87's Avatar
just keep pulling try twisting on it but...dont grab right where the hose goes over the piece cuz then your applying pressure to the hose keeping it on the piece squeeze a lil off of were it adapts and jus keep at it once you get it going it will come off.
Old 07-29-2006, 10:10 AM
Tech Resident
ChocoTaco369's Avatar
this is what i had to do. jam a flathead into it and twist/pull like your life depensd on it.
Old 07-29-2006, 10:53 AM
Z28Camaro01's Avatar
Same for me lol
Old 07-29-2006, 11:11 AM
LS1Aggie09's Avatar
what happens if you do break that brake booster piece? how hard is it to break?
Old 07-29-2006, 03:42 PM
Before using the screw driver, I was applying a decent amount of pressure on that piece and it didn’t break. I don't think you have to worry about breaking it. Any luck getting the hose off?
Old 07-29-2006, 05:09 PM
Joey7489's Avatar
Its normal for it to wiggle, it wiggled on mine also. It wont break dont wry. Just jam a flathead in there and tug.
Old 07-30-2006, 11:32 PM
burnrubr88's Avatar
you can pull that little piece that goes into the brake booster out. just pull it straight out and then it is easier to pull the hose off. plug the piece back in and your set.
Old 07-30-2006, 11:47 PM
SHINER's Avatar
that thing wont break trust me.
Old 07-30-2006, 11:52 PM
LS1Aggie09's Avatar
howdy...yea i finally got it off and did it this morning...damn, what a difference that stuff made. watchin that huge cloud behind me was the best part. motor tapped a bit at 3k rpms but then quit after it quit blowing smoke, then i changed the oil. shes running so smooth now. Loudmouth goes on in a week or two....thanks for the input
Old 07-31-2006, 12:05 AM
SHINER's Avatar
no problem man keep us updated on your ride!
