Daytime running lamp
My running lamp on the driver side is not on and the blinker stays on and does not blink. When I had my firebird do this I just put up the haedlights reached down in there and changed the bulb. On the T/A the lamps are on the outside and I can't quite reach down to it. My question is am I going to have to jack it up and remove the bolts underneath to get at it just to change the damn bulb? Has anyone else had this problem, and were you able to change without jacking up the car?
I've managed to change it on my T/A by sticking my hand through the hole (brake duct in theory) under the light and pulling it out from there. Scrapes up the arms a little but its less time consuming than jacking it up and dropping the splash shield
