Turn signals work when they want
Yesterday my turn signals stopped flashing. The bulbs come on but they won't flash. All the fuses are good and I changed the flasher, but no luck. The really wierd thing is that tonight, for no reason, they just started working again, but flashing all wierd, starting out fast, slowing uo then getting fast again. Any suggestions?
its your ls6, take it out and ship it to me, ill send you the ls1 and itll fix the problem...haha, i have no idea, could be something loose in the column, my brights only work when i tilt it at certain angles?
Originally Posted by keliente
Chances are the sockets are corroded or burned up (common). Then they just do whatever they want. Too much resistance doesn't make for good electricity flow - so you get that on again off again kind of operation.
I think I would just go ahead and spend $7 on the socket itself instead of trying to save it by cleaning it. It should be obvious when you look at it - often the plastic will be melted, the terminals will be corroded, or the socket will have turned brown. And yeah don't skip the dielectric grease this time like jkichline said.
Thanks for all of the replys! It's both signals and the sockets are good, but everything stopped working all together this morning on my way to work. I'm guessing it may be the switch in the column, so off to the dealer I go to be raked over the coals!
I got my switch at advance a few years back and its still working fine. I remember it being MUCH cheaper than the dealer part.
By the way, the $7 socket is crap. It works (for now), but its crap.
