car is making lots of funny sounds when turning
Old 08-23-2006, 08:52 PM
chrisryn64's Avatar
Default car is making lots of funny sounds when turning
First of all my car seems to be falling apart. My latest problem is with turning. When ever I go to make a turn, especially under lower speeds I hear lots of strange sounds coming from under my car. The best way to explain them are popping sounds and straining sounds, if that makes any sense.
I'm sure it has something to do with my steering rack upfront but I'm not sure where to start looking or how to even fix it.
Maybe someone with this problem knows the best way to get it back to making no noises when turning.
Old 08-23-2006, 10:24 PM
slowpoke96z28's Avatar
left turns, right turns, or both? any leaks/is the fluid level correct? also remember, balljoints like to pop and creak when they go bad, and so do wheel bearings if they cot trash or junk in them. does it kind of sound like a front wheel drive car with a bad CV shaft?
Old 08-23-2006, 10:27 PM
christsbane's Avatar
i have the same exact problem, does your power steering cut out at low rpms?
Old 08-23-2006, 10:30 PM
chrisryn64's Avatar
It makes the sounds regardless of which way I turn. First thing I did was check my power steering. The fluid level is full and it never feels like it goes out. I just had a wheel hub replaced on the passenger side so I'm not sure if that's it.
Balljoints seem like a good place to start. Is there a good guide to that assembly anywhere?
Old 08-24-2006, 11:35 AM
chrisryn64's Avatar
After driving it around some more it definatly sounds like it's coming from wheel area
Old 08-24-2006, 02:42 PM
jkichline's Avatar
Start simple, check your lugs and make sure they're tight.
Old 08-24-2006, 08:11 PM
Dal1as's Avatar
Grease your sway bar u-bushings and endlinks.
Old 08-24-2006, 11:44 PM
Ehatcher's Avatar
mine does the exact same thing ... and my car feels like it is falling apart also. Im guessing it is the wheel bearings or something to do with that general area. It pops when making a right hand turn and accellerate a bit. and also when the car isnt accellerating or if i let off the gas and let it roll , i get a wo-wo-wo-wo sound, as if i have a flat spot in the tire but there isnt one. Im interested aswell for fixes for these problems.
Old 08-25-2006, 11:19 PM
Blackhawk777's Avatar
That popping noise when you turn is just your Posi rear. Mine does it too.
Old 08-26-2006, 12:11 AM
Ehatcher's Avatar
There is no way that a perfrctly fuctioning car could pop and make noises like these. I was just trying to gain ideas and assumptions before i actually went into looking for the problem, mainly to get a basic idea of what could go wrong with the car. It just rolled 94,000 miles, so im not completely upset that some things may need to be replaced.
Old 08-26-2006, 08:53 AM
chrisryn64's Avatar
I don't think so. This is definatly coming from the front somewhere
Old 08-26-2006, 10:52 AM
bww3588's Avatar
mine makes a popping noise when i turn the wheel left or right of center., then when i turn left on a low speed turn it makes a groaning noise.....im going to check everything out when i have it up on a lift to put my exhaust on.
Quick Reply: car is making lots of funny sounds when turning
