Airbags removed, how to turn off the dash light?
Old 10-17-2006, 09:32 PM
motorbuilt's Avatar
Default Airbags removed, how to turn off the dash light?
Airbags are removed from fbody and I need to turn off the Dash cluster airbag light that is on constnatly, how do i turn off the permanently the easiest ?
Old 10-17-2006, 09:34 PM
nilestracing's Avatar
remove the bulb lol
Old 10-17-2006, 09:38 PM
motorbuilt's Avatar
I've heard removing bulb can trigger SES light etc and I wanted to avoid that....
my search on here had an "idea" of cuttin brown wire in 24-pin connector behind glove box but it was for an LT1 car so no confirmation.
Old 10-17-2006, 11:49 PM
2002_Z28_Six_Speed's Avatar
There is a way to turn the light off if you can very very closely match the resistance of the airbag and place it inline with the circuitry. It involves a resistor network not worth building due to fine tuning. I have done it before and it was a pain in the *** to dial in and build. Worked perfectly though!
No light and no undo-able mods!
Old 10-18-2006, 01:12 AM
tx3
tx3's Avatar
a piece of electrical tape
Old 10-18-2006, 01:41 AM
staringback05's Avatar
tune them out...might sound awkward, but you can get the pcm to not recognize the airbag sensors...cant remember exactly the tuning suite that was used, but i saw it done about 4 years ago while i was learning about these cars
Old 10-18-2006, 09:36 AM
motorbuilt's Avatar
There is nothing in HPTuners that allows me to turn off the light..its controlled outside of the PCM.
Anyone else have an idea?
Old 10-18-2006, 10:27 AM
Unless you work at Bosch or wherever you aren't going to be reprogramming that thing.
I would suck it up and build the resistor network.
Old 10-18-2006, 11:09 AM
hmm i dont think what i saw used was hp tuners anyways, but im pretty sure you can the sensor off....ive seen it done on a 99 trans am, like mine about 4 years ago, and any ses light...goes through the computer
but if its easier to use some tape...do it
Old 10-20-2006, 04:03 PM
pull that bulb too lol when i got done with my 6.0 swap my guages lit up like a christmas tree lol abs traction airbag service engine soon seatbelt skipshift theres so many stupid light i pulled em all it ran fine...
Old 10-20-2006, 04:11 PM
01WS6er's Avatar
The last light I got rid of I tore the cluster apart and put 3 layers of elec tape over the bulb and put it back together. The cluster I had had leds instead of light bulbs.
Quick Reply: Airbags removed, how to turn off the dash light?
