hatch wont open
Old 12-28-2006, 04:37 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default hatch wont open
My hatch wont pop.... Not by fob, not by key, or by the hatch button under the dash...
Any ideas?
Old 12-28-2006, 05:31 PM
2001NBMZ28's Avatar
Strange it won't work with the key at least. Have you tried keeping the key turned and pulling up and down on it?
Old 12-28-2006, 05:32 PM
Sgt. Spuds's Avatar
key wont turn
Old 12-28-2006, 05:56 PM
2001NBMZ28's Avatar
Weird. Other than climbing back there and trying to pop the latch open with a screwdriver to see what's going on only other thing I can think of is put downward pressure on it, then trying to get the key to turn. Only strange hatch incident I've had is mine popped by itself when a battery died.
Old 12-28-2006, 07:36 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
once i closed it with a bit of a blanket that got stuck in the lock itself---would not open by key either..had to crawl in and grab the little bit of blanket and pulled....might be a similar problem...
Old 12-29-2006, 03:58 PM
Sgt. Spuds's Avatar
Still nothing..
Old 12-29-2006, 04:01 PM
HIZPANICGUY21's Avatar
hmmmm..this is wierd
Old 12-29-2006, 04:18 PM
2001NBMZ28's Avatar
Fuse is good? On mine the PWR ACCY fuse controls the hatch release relay. Doesn't explain why the key won't work though...
Old 12-29-2006, 09:01 PM
Sgt. Spuds's Avatar
Now that I think of it I don't think the key would ever worked :blush:
