s.e.s light is on
s.e.s light is on
hi i have a question
i was cruising my car today was running fine
and out know were the s.e.s light came on
but car still is running fine
i had it tuned about year ago
anyone know what it might be
LS1Tech Administrator
Received 1,493 Likes
What’s the worst ting it could be?
car is running the same way it did with no light on
Ses Light Is On
ok i got it scanned the code is p1133
the guy told me he check on his computer and it said
insufficent switching sensor 1/bank 1 fuel control shifted lean so.
i wanted know if it can be fixed with tuner or maybe sensor or
is it mechanical ............................................anyone know?
its from your o2s. like posted above long tube headers will cause this problem, since the o2 sensors do not heat up as much as with the stock headers causing the o2 to read incorrectly and the code to pop up. i would clear the code for now, and see if it comes back on. if so id try the bosch o2s. the part number is 13111. they have higher wattage heaters to prevent this problem from happening.
