HELP! car died after 10 mintues of driving
i was driving to my girlfriends house tonight and noticed that my headlights were very dim. looked at the battery gauge and it was almost in the dotted red zone. as soon as i got on the highway, all the lights got brighter and the gauge shot up to normal. then it gradually went back down in the red until the car eventually died. i checked under the hood and the positive terminal has some major corrosion on it which i'm going to take a wire brush to it tomorrow and see if that helps. when i try to start it now you can hear a bunch of fast clicks but thats it. lights will still come on, so its not completely dead.
what do you think happened? possibly the alternator died and the car was just running off the battery until it died? maybe the corrosion on the terminal is so bad that its completely lost a connection? i tried jumping it and all i get are those fast clicks.
if anyone can give any advice it would be greatly appreciated!
thanks!
thanks!
thanks!
thanks!
well, i had it towed this morning. just picked it up from the shop. $160 freaking dollars for diagnostics, new battery and installation!!! drove it home and started doing the same thing. battery draining very quick. what the hell! obviously they didn't check the alternator...
you guys that are shop frequenters, should i be pretty pissed? how should i handle this? i'm having to take it back up to the shop tonight so they can fix it for good tomorrow but i'm not really happy about another day without a car and having to shell out more money.
is it possible that my old battery was good, just dead due to running off the battery after the alt died? or could it be possible that running off the battery while driving completely ruined it, justifying a new battery. i did see the positive terminal on it, and it was pretty caked with corrosion. i'm wondering if they would have just fixed the alternator from the get go, the old battery would have been fine with just a charge??? they said the battery tested bad...
well, they just called to let me know the car's done. they put an alternator in it afterall, like the should have f'ing done yesterday. $311.50!? does that sound right? not to mention the $160 for the battery yesterday...
$311 for an alternator? My car did the same thing, I though it was the alternator which was like $160 or so... But what it turned out to be was the plug that connects the alternator to the computer.. A wire pulled out of the plug in the aternator... So I replaced the alternaor when all i needed was a $5 part and that solved my problem
