Help with my DRL/Blinker.
OK heres the problem #1 My right front running lamp will not come on only with the headlights on.#2 Also the right front blinker will not blink but the left side does blink all I get is the green arrow inside it stays on constant,but when I put the hazards on they all blink fine.#3 The right rear blinker just stays lit,can someone help me here any advice thank you.
Originally Posted by Formula413
Two things to try:
Check the flasher for the turn signals, there are two flashers, one for turn signals and one for hazards.
More importantly: Check for a bad ground or any other loose connections. A bad ground can make lights do all kinds of wierd stuff.
You need a new bulb on the right. The DRL is brighter than the normal park light that comes on when you turn on your lights. The bulb has 2 filaments, the one that makes the DRL and turn signals work is burned out. That's why the park light works but neither the DRL or turn signal does.
yeah but he said his 4 ways work fine. so both filaments in the bulb are good.
Maybe, but the solid green arrow is the indication for turn signal not working. When one side of the blinkers go out both the front and back stop working on that side. It's a bulb, and cheap. Good starting point.
Originally Posted by 02BEAST
I never heard of blinker fluid were does it go?And also how the hell do I get the bulb out my hand won't reach is there another way without taking the headlight out?
To take the blinker out there is a little trap door underneath the car, just take out the 2 bolts for the door and the blinker is right there.
Originally Posted by brad8266
Go to autozone and ask for it, they keep it behind the counter. or order it here http://kalecoauto.com/index.php?main...&products_id=6
Where do you pour it into?
If I knew you lived like a mile from autozone I would have kept it going so that when you go the autozone guys laugh at ya.
Man we got you hook and sinker, lol. There is no such thing as blinker fluid man. Its a joke. I would let it go on but I really dont want you to drive all the way to autozone since I dont know where you live and autozone may be really far away.
I knew something was fishy because I never heard of it.
Back on topic now. You may need new blinker sockets, I had to replace mine a long time ago becuse they got corroded, part if the problem was that the front lens gets tiny cracks in them that water goes through, I replaced the sockets, put some clear RTV coating on the lens', and it has been good to go ever since.
