Ok Coolant Question, Somebody Chime In And Help!
Ok i have totally flushed my coolant system ( with the prestone flush kit) got it all back to straight water and was planning on using green stuff & distilled water to put back in it ! Yes, i know your suppose to use the orange stuff (dex-cool) but i feel safer using green and plan on flushing it every 1-1/2 yrs at the most, so what type of green stuff do you use i know the extended life prestone is just like dex-cool without the orange color and i want to stay away from anything similar to dex-cool! Is there a straight green brand i can use with distilled water? let me know thanks .........
LS1Tech Administrator
Received 1,794 Likes
If you plan to flush it every 1-2 years, dexcool would never do you any harm. Just something to keep in mind.
Most autoparts stores around me still have striaght green coolant, if that's what you really want.
dont wanna deal with dex-cool because of rumors...... eating seals up, it really dont start protecting till afrer 5000 miles ....etc..and the deal with air lock in your system if you have a small leak it will clump up supposidly ......green seems easier to deal with in my case.... im looking for someone that runs green in their own car and a brand name.....
Originally Posted by CULATR
https://ls1tech.com/forums/showthrea...=coolant+flush
and this is the november 2006 issue of the magazine !!!
yea, that article and all the hype on the orange stuff you see on here and there's alot ....plus my uncle found out i was going to flush my coolant and said your not going to put that orange stuff back in there are you? when i said yea, why ? he says because its know to eat stuff up and is acidic based which pretty much sold me being he's a mechanic and his other mechanic that works on car's, both told me to use green instead then i came upon the article so ....im planning on putting in green was just curious what brand someone was already possibly running......
I just flushed out my dexcool and went to universal green coolant and I'm not looking back. I've heard way too much against dexcool from many informed sources. As for the assertion that dexcool is less corrosive to aluminum blocks, that may be true, but like ChocoTaco says, your block will still be intact after you are dead and your car is rusting in a junkyard. In the here and now, I'd give more thought to your waterpump, gaskets etc...
If you are going to flush your coolant every two years anyway, you might as well use green, since the main benefit of dexcool is that it is designed to last for five years.
I've had about a half dozen dexcool-only cars over the last 10 years now. It's never once caused me a problem. And it never will, so long as you change out the coolant every 2-3 years.
There is not a single article that will mean more to me than my own personal experiance.
And for those of you that think green stuff does no harm, I've had plenty of problems with that stuff on my older cars, so think again.
Moral of the story:
No matter what coolant you use, change it out often, and you won't have any problems..... don't change it out often, and you're just asking for trouble, no matter what type it is.
Moral of the story:
Talked to my bud at the dealership there's no brob with Dexcool at all as long as you change out the coolant every 1-2 or 2-3 years like RPM WS6 said.
thanks for the info i decided being as i'll change it out every 1-2.5yrs im going to go with the green stuff ....thanks though
Originally Posted by Camaroz
You better hope you get all of the dexcool out of the block. Also Green is much more harsh on aluminum blocks. All this talk about green being proven and better... Why are all the big name car manufacturers not using green still then? This is why Choco shouldn't be allowed to lose his virginity and reproduce
choco had nothing to do with me deciding to use green and right now all i have in my block is pure distillled water and just to be safe i've been draining it and refilling it everyday for the last 3 days to make sure alll was clear...... i know if both orange/green are in your car it will eat away at aluminum and so on but has it been proven that green will eat up aluminum by itself??? this made me decided to use green stuff... read this out of the master tech magazine...https://ls1tech.com/forums/showt...t=coolant+flush
yes the dexcool stuff is fine aslong as you keep it maintained ie flush drain or refill periodicaly i work at a gm dealer as a tech. from some of the stuff i have seen come thru there, i just go ahead and use the green stuff in my cars. air is dexcools worst enemy it will turn to a clay like substance with in a few months. have seen happen on almost brand new cars
Kleeborp the Moderator™
