Rear Main Seal
Rear Main Seal
HOW DO YOU CHANGE THE REAR SEAL? i took the trans off to get rebuilt and got new flexplate cause i broke the last one.. so i ordered the rear main seal kit a circle gasget and a rear cover gasget seal... any help
If you got a new gm seal it is a new revised version that no longer needs the special tool to install it. The new seal says this side out in super small letters. Just grease the end of the crank slip it around the crank and then push it in so that it is flush with the taper on the rear cover. The new ones I have done were able to be pushed on without even having to use a small hammer to tap it down.
i pulled the entire back cover wich was easier nocked the old one out put new one in with new cover gasket tightened them just enough and the seal seems to be even all around so i guess ill find out if it leaks
Ow i didnt know they changed it, cool mines got a small leak i noticed the other day when i got under the rack guess i'll get around to it sometime soon.........hey anybody possibly got the new number to the revised seal??
I tell you what if I was you I would probably go ahead and change the rear cover gasket just to cya. I just got done pulling a tranny twice to find the cover gasket was leaking while the engine was running.
yea i was planning on changing the rear gasket regardless just to be safe y'know.... also was the number to the rear seal changed being as it was revised??
