fram, K&n, blackwing air filter
i got the fram air hog filter, i am using the tray. it fits like crap. the clips that hold the lid on are barely on. one actually popped off when i drove it. should i use the tray still? also does anyone else have this problem?
thanks
thanks
((((((Administrator))))))
Do you have a foam seal on the inside of your lid from a K&N filter in the past?
If so, then there is your problem. K&N is a shorter filter and has to have the foam weather stripping seal on the inside of your lid.
If you do have that foam stripping and want to continue to use the Fram, just peel it off.
Peace,
Craig.
Peace,
Craig.
LS1Tech Administrator
Received 1,493 Likes
Peace,
Craig.
Peace,
Craig.
Some people don't even realize they have this gasket, if they bought the car used and the previous owner installed a K&N.
no i dont have the gasket. the car had that factory paper filter
I dont have the K&N gasket on my blackwing because my lid barley closes with the K&N filter. Do you recomend I buy a gasket and force it to fit? What does everyone else use with their K&N?
