cant open hatch with key?
i got my car 8 mos ago and never used my key to open the hatch, ive always used the remote, the other day i used my key for kicks, the key slides right in but wont turn! whats up with that? thanks
That's strange, does the key work in the doors/t-tops OK? Mine works better with the key - don't have to keep hitting the 2X 3 or 4 times to get it to pop.
Originally Posted by koolaid_kid
It sounds like the hatch and/or lock has been changed. If you pull it out and take it to a locksmith, they can rekey it to your key.
edit: oops didn't see you just got the car 8 months ago. I'm glad to see I was right for a change.
Copy & Paste Moderator
Originally Posted by ArcticZ28
FYI, there's a mod for this that involves buying a heavier duty spring that pops the hatch open better. It should be around the forum somewhere. I remember seeing it a long time ago.
I replaced my spring instead of the piggy-back method though.
1 Post
Originally Posted by sdm1234
in case you didn't know, u have to wait at least one second after hitting it initially for the hatch to pop up. that's a safety feature so you don't accidentally hit the button at a random time and it pops out of nowhere.
As long as the car is in Park (A4), it opens immediately with the press of the yellow button. If the car is not in Park (A4), the button won't open the hatch. On the M6, I think the e-brake performs the safety lockout feature. Can anyone with a M6 confirm?
Originally Posted by VIP1
Not on mine.
yes my key works on the glove box.
wait a minute here, when you guys press the yellow button or your remotes, the trunk pops open?? like all the way open? mine just unlocks and i have to pull it up like the hood... is the popping up thing stock?
I think he's referring to the button on the remote that you have to hold down to pop the hatch, not the yellow button inside the car.
Originally Posted by vikingramair
Before doing something else, lubricate the lock and check. WD-40 or something...
hmm, yeah, i'll try that. could be just really jammed cause seriously, who really uses the key? thats so 1995
