replacing steering rack, cut the bolt?
I am in the process of replacing my rack, and everythings ready to come off, but the drivers side bolt that's in the x-member is 2 long, or I need to take off the oilpan to remove it? What should I do? Help is greatttlyyyy appreciated
Thanks a lot,
Michael
Thanks a lot,
Michael
Ok, what should I jack the motor up on? Like where at on the motor, I'm a little iffy on jackin **** up on my car, and should I go ahead and change the motormounts while I'm doin this?(car has 100k miles on it) how hard is it if I should? And which ones should I use? Polyurethane? Etc most of my bushings are shotttt as in tearing,,
Thanks a lot
Michael
Thanks a lot
Michael
Thanks a lot
Michael
Thanks a lot
Michael
I put a wood block under my oil pan and jacked it up there.
