Help please! Can I drive the car without power-steering fluid?
Old 07-10-2007, 05:18 AM
Vetal's Avatar
Default Help please! Can I drive the car without power-steering fluid?
There's a hole in one of the pipes, and I need to drive some 250 miles. Can I drive the car without fluid in the power-steering?
Old 07-10-2007, 05:40 AM
2MuchRiceMakesMeSick's Avatar
You would probably burn up your power steering pump. Why not find a way to temporarily patch the hole?
Old 07-10-2007, 05:45 AM
Vetal's Avatar
No way... Car far from home - I'll be there in the night...
Maybe I can take off power steering belt and drive in that way?
Old 07-10-2007, 07:06 AM
UCFWS6's Avatar
250 miles?! hope your upper body is in shape
Old 07-10-2007, 09:12 PM
Danny2tek's Avatar
I would buy a shitload of fluid and keep topping it off. You will kill that pump without fluid
Old 07-10-2007, 09:15 PM
619SS's Avatar
One in of the pipes or hoses? Can check in a ghetto fix it kit?
Old 07-10-2007, 10:10 PM
WestSide's Avatar
Patch the hole or bypass the pulley, constantly filling it only to drip on your alternator won't help your trip.
Old 07-10-2007, 10:58 PM
_JB_'s Avatar
Isn't the alternator on the passenger side?
Old 07-11-2007, 12:40 AM
Shallow Bay's Avatar
No, it’s on the driver’s side.
Attached Thumbnails Help please! Can I drive the car without power-steering fluid?-alternator.jpg
Old 07-11-2007, 08:34 AM
GregAbell60143's Avatar
There really isn't an easy way to bypass the PS pulley.
If for whatever reason you have to drive it like it is, before getting it fixed, maybe try adding PS fluid with stopleak in it. Top it off, drive for a couple hours, top it off again. It's not ideal, but that might work for you short-term.
Old 07-11-2007, 09:17 AM
Jon5212's Avatar
If its leaking from the steel line try getting a piece of transmission rubber hose and slit it vertically to wrap around the steel line and use 2 hose clamps on it, that should hold temporarily. Kind of like you wrap the clutch line with heater hose. But get it right over the hole in it. If thats where it is leaking.
Old 07-13-2007, 03:04 AM
Vetal's Avatar
OK guys thanx for your advices, car was brought home I kept topping it (although it didn't loose much fluid over 4.5 hours). Leak is from connection of metal line to pump (?) body. Will try to fasten this connection. However, now I have much much more serious problems, I'll make new topic now.
Old 07-13-2007, 03:05 AM
Vetal's Avatar
BTW, where can I get this manual that was quoted by "Shallow Bay"?
Old 07-13-2007, 04:22 AM
I just bought a 98-05 GM Service Repair Manual on DVD off eBay for $48 shipped. It doesn't look like the particular seller has any more available. Are you looking for a specific kind of information?
Old 07-13-2007, 04:39 AM
Vetal's Avatar
No, not specific, simply I cannot own vehicle without having manual
Wow, that's odd, Nissan manuals (I'm Nissan Silvia guy ) are usually freely downloadable
Quick Reply: Help please! Can I drive the car without power-steering fluid?
