Correct Volts Reading?
Old 08-02-2007, 12:49 AM
italicizedsponge's Avatar
Default Correct Volts Reading?
Hi I have a 98 camaro z28 A4 with 101,000 miles. when the car is running the voltmeter only reads a little under 13 volts and its a little in the red when the A/C is on, Do i need a new battery for sure before i waste my money?
Old 08-02-2007, 02:59 AM
DaddySS's Avatar
A couple for things;
First if it's the original battery you should consider a new one no matter what - 9 years is the upper limit for batteries.
Second, what options and mods do you have on the car?
What is your idle speed?
Do you have a volt meter to accurately check voltage?
Old 08-02-2007, 09:18 AM
Nemo02Z's Avatar
Go to the auto parts store and borrow their load tester for your battery and if the battery does not fall on its face after a few seconds then its good.
Old 08-02-2007, 11:09 AM
Desert Rat's Avatar
Just been through this. It was my alternator. I replaced it and problems persisted. Turns out I got a bad new one at the parts store. Replaced it for the second time last night and it's now making just over 13.
Other things it might be is the excitor wire that comes off the voltage regualtor in the alternator (the plug on the top of the alt). I replaced that too for good measure.
Do get the battery tested first though. That's the cheapest and easiest.
Old 08-02-2007, 12:02 PM
bayer-z28's Avatar
^ FWIW: NAPA Alt's suck! I went thru three on my 85 until I got a good one.
Do you have UD pulleys? I've heard of charging issues w/ UD pulleys on autos..
It should read 13.5vdc.
Old 08-02-2007, 02:57 PM
Desert Rat's Avatar
No UD pulleys.
I have the equivelently shitty Auto Zone version in the car. I had the second one bench tested before I left the store and it came up good. We'll see.
Old 08-02-2007, 03:00 PM
ae13291's Avatar
well my car never had any problems wit voltage but it was around low 13 before i added a grounding kit and voltage stabilizer and cleaned all the factory grounding points (factory never took the paint off the grounding surface) my voltage is now ALWAYS over 13 no matter what!!! when i start it in the morning its about 15 , but your car seems to have a problem most likely alternator brushes going bad, OR one one of my other cars i had a faulty working battery guage lol man that stupid gauge made me go throgh three alternators and all of them giving me the same resalts and i ended up finden out the guage had a bad ground, so check that out to aswell. goodluck
Old 08-02-2007, 09:21 PM
turns out it was my battery but too late because my car wouldnt start when i tried to leave my house today, lol but its getting a new battery tomorrow and passenger window motor
