i wonder what I broke....
Old 08-31-2007, 08:42 AM
1998Z28LOADED's Avatar
Default i wonder what I broke....
Ok, to make a long story short, I was being and idiot and I spun out going 100 mph. I went around in two circles, the second one was off the side of the road. The outside of my DS front wheel hit the ditch hard enough that little rocks broke the bead in the tire. I got the tire fixed but I think I broke something else. I have a constant break like (like when your pads need replaced) squeal from the wheel at all times that my wheels arent pointed even slightly to the right. Also when I break I get a "wa-wah-wah" noice from the wheel area also.... If anyone could help me out I would be much thankful...
Thank You,
-Ronnie
Old 08-31-2007, 09:01 AM
s10blaza's Avatar
well have you inspected the brakes? I'd start there since that's where the noise is coming from.
Old 08-31-2007, 11:39 AM
I ran my fingers in and around them when the tire shop had the wheel off. Everything looked intact.
Old 08-31-2007, 11:45 AM
Ericbigmac83's Avatar
Take the wheel off and spin the rotor and see if it makes that noise
Old 08-31-2007, 11:46 AM
will do, Im headed out to try and get to the bottom of this now. If anyone else has suggestions, Ill be coming back in to check the thead every so often... thanks again fellas.
Old 08-31-2007, 10:16 PM
Viper's Avatar
What did you find?
Old 08-31-2007, 10:59 PM
venom346's Avatar
Damn, you spun out at 100 mph? you're lucky to een be alive and un-injured ! =)
as for your wheel, maybe you slightly bent /warped a rotor?
Old 08-31-2007, 11:11 PM
SladeX's Avatar
I'm going with bent wheel...
Old 09-01-2007, 12:10 AM
Camaroz's Avatar
Your one lucky son of a bitch
Old 09-01-2007, 02:15 PM
jareed02's Avatar
thats what i think too
Old 09-01-2007, 03:25 PM
deadlift's Avatar
check alignment too
Old 09-02-2007, 02:21 PM
I couldnt find anything at all. Everything was tight and intact. I really hope it's not a bent wheel.
Yes I know Im lucky to be alive, I was actually passing a tanker semi when I spun. I was going in circles while I passed him. Shot back out into the road right beside it. Close call for sure.
Old 09-03-2007, 06:21 PM
venom346's Avatar
To rule out a bent wheel, try, rotating wheels or putting on your spar tire so you can track down and eliminate that possibility
Old 09-03-2007, 09:16 PM
lowboy580's Avatar
your caliper is not hitting the wheel on the inside is it? jack it up and spin the tire while it is in the air.
Old 09-03-2007, 09:22 PM
99z28monster's Avatar
maybe bent tie rod end?
Old 09-04-2007, 02:03 PM
Im gonna have my dad look at it tonight. He knows everything, I just didnt wanna ask cause I feel like an idiot 4 screwing up my Z.
Old 09-07-2007, 10:08 PM
For those wondering I had a warped rotor and a broken sway bar.
(I cant complain really, 100 mph spin outs are nearly worth the fun)
Old 09-07-2007, 10:47 PM
thebufenator's Avatar
get a strano 35mm bar
Old 09-10-2007, 11:35 PM
Ok Ive had my new rotor on for two days(the noises had stopped). Now the squeeking and the grinding noise at low speeds is back. Its no doubt coming from the breaks/rotor. What else could be broke?
Old 09-11-2007, 03:39 PM
question's Avatar
Sure its not coming from the rear end? I know it sounds far fetched, but have someone listen OUTSIDE the car while you drive.-
