Gear Shifter Button (Automatic Tranny) Gets Stuck
Old 10-10-2007, 02:02 PM
BigBas83's Avatar
Default Gear Shifter Button (Automatic Tranny) Gets Stuck
This is a relatively new, and annoying problem that I am having with my 1998 Trans AM. After the car sits for a few hours, when I try to press the button on the side of the gear selector (to shift out of park), the button is stuck. I have to really squeeze hard, sometimes using both hands, to get it to move. If I need to shift again soon after, it doesn't get stuck.
Any explanations/solutions?
Old 10-10-2007, 03:35 PM
2001NBMZ28's Avatar
Might just be the handle itself. I'd try removing the handle and pressing down the button on top of the shifter and see if it still happens. Only happening after the car has been sitting a few hours has be baffled.
Old 10-10-2007, 04:48 PM
camaroguy26's Avatar
maybe somehow the handle gets pushed hard towards the lock making it harder to squeeze the button. Kinda like if you pull up really hard on your e-brake, it's hard to squeeze the button to pop it out. Take off the cover and see if you can see where it's binding up at.
Old 10-10-2007, 10:40 PM
ghardester's Avatar
The T-handle goes out some times. Mine on the '97 started that way. Pull out the little staple on the side and remove the handle to check things out. Shift to neutral first so the shifter is straight up. I had to replace my handle. Not a big deal, just one of those plastic part things.
Old 10-11-2007, 09:01 AM
BigBas83's Avatar
So, I tried to get the handle off of my shifter, and I failed. Can anyone provide details on doing this?
Old 10-11-2007, 12:40 PM
2001NBMZ28's Avatar
Turn the key on so you can put the shifter in first. Midway down on the handle (the side facing the dash) pry out the staple with a small screw driver. Once the staple is removed just pull straignt up on the handle.
Old 10-11-2007, 06:41 PM
Formula413's Avatar
You don't happen to have that old handle, do you? Mine is missing the button.
Old 10-11-2007, 08:45 PM
ghardester's Avatar
No, sorry, that was several years ago.
Old 03-14-2023, 03:27 PM
Barr's Avatar
Default Push button
Slightly lift up push button first then push in , my mas car just sat 4 months , running for 30 mins goes in couldn't get out of gear I checked it out slight lift on button then push easy as pie. For my case 98 lt1 trans am convertible baby
Old 03-15-2023, 02:37 PM
bleepster's Avatar
15 years later - i hope he has it fixed - LOL
Quick Reply: Gear Shifter Button (Automatic Tranny) Gets Stuck
