Lights are flickering??
Old 11-09-2007, 03:17 PM
spec_j's Avatar
Default Lights are flickering??
Ok car has been doing this for a few months now and im finially able to have the time and money to fix this. The lights IE: headlights, dashlights every light flickers like i have a low battery. I have a new battery in the car, and the volts are reading normal even on a volt meter. Im thinking its the alternator is pulling power or not charging the battery properly. Ideas, suggestions solutions???
HELP ME!!!
Old 11-09-2007, 03:36 PM
Luder[PAK9]'s Avatar
I have this problem too. Though it's very subtle and usually stops after the car has been running for awhile. I know my serp. belt is worn and am hoping my replacing it this weekend fixes the problem.
Kinda weird b/c my 1991 did the same thing too.
Old 11-09-2007, 10:37 PM
spec_j's Avatar
hmmmm makes sense to me. Please let me know if that fixes it. And ahow much was the belt?? nad do you have a part number?
Old 11-09-2007, 11:57 PM
FormulaSS's Avatar
Question
I changed my alternator and belt recently and I have this problem on my '95 Z28.
Old 11-10-2007, 12:06 AM
Danger731's Avatar
Demons
Old 11-10-2007, 01:38 AM
Phil8616's Avatar
You changed the alternator and belt and it didn't fix it or did it solve the problem?
I have the same problem, but my voltage gauge moves back and forth as well...
Old 11-10-2007, 08:49 AM
sixvi6-camaro's Avatar
mine was doing that. I had a new battery, cleaned all the grounds and checked all the cables I did find the main power cable from the battery to the alternator was frayed. I replaced it with some 2 GA car audio cable I had around and the flickering went away... but then about 3 months later it got soo bad one night it looked like I was flashing my lights. Next day I pulled the alternator and had it tested. Turned out the alternator was bad so I replaced it and no other problems since.
Old 11-10-2007, 11:20 AM
crapyboy750's Avatar
i had the same problem when i bought my car it was because the alternator was going out.
Old 11-10-2007, 12:50 PM
spec_j's Avatar
hmm alternator mine be going out huh, i will have to throw a tester on there an see what volts it puts out
Old 11-10-2007, 10:50 PM
FormulaSS's Avatar
I recently purchased the car and the voltage guage was dropping like crazy so I put a new alternator in it and while I was at it I changed the belt as the old one was cracked. Just noticed the slight flicker when cold and driving at night. I don't notice anything after it is warm though. Weird!
Old 11-12-2007, 09:23 PM
spec_j's Avatar
i think i just have to fork up the $160 for hte new alternator
Old 11-13-2007, 12:16 AM
SiNFuLL's Avatar
Mine done this for awhile. The new alternator solved the problem!
Old 11-13-2007, 01:56 AM
waldershrek's Avatar
What did the test on your alternator find out?
Old 11-13-2007, 08:53 AM
I replaced my belts last weekend and it didn't solve my flickering problem. I should clarify and say I don't notice the flickering while driving (though that's not to say it's not really there), only at idle.
Old 11-13-2007, 08:58 AM
Greggy's Avatar
Most of these alts. do it...even my replacement AZ Gold one did it soon after install.
Old 11-13-2007, 09:12 AM
Reading this thread on replacement alts, two people said their cars flickered from day one, so it could be just one of those f-body quirks.
https://ls1tech.com/forums/generation-iii-external-engine/646935-alternator.html
Old 11-16-2007, 01:05 PM
spec_j's Avatar
https://ls1tech.com/forums/showthread.php?t=646935
thanks for the info man
Old 11-19-2007, 10:31 AM
SiNFuLL's Avatar
My old one tested to be fine. I don't know what the deal was with it because it was working fine except for the flickering lights. I kept my old one and hope to get it rebuilt or whatever to put in the race car we're building. Everyone I had talked to about the flickering that said they had it claimed it was a wiring issue and had given me horror stories on how they had to get the dealership to replace wiring. I tried the cheaper route first and it solved my problem.
Old 11-23-2007, 01:16 AM
Goldfinger911's Avatar
My 2002 WS6 is flickering too. I only have 25k miles on it too. One thing I noticed... the flickering is not from voltage drops... it is actually voltage spikes, then returning to normal voltage. When my car idles, I get 14.55 volts at the battery. When I have driven the car a while, I get 14.10 volts still. What does everyone else see when idling? (Use an accurate multi-meter instead of the dash voltage gauge.)
Old 03-02-2008, 01:02 AM
spec_j's Avatar
UPDATE:
i changed the belts after working my *** off for the last few months and actually getting time to, and it seemed to help ALOT
